ecm schematic
biggin
ecm schematic
Post by biggin »
I need an ecm schematic for a 2005 vibe. any help would be much apreciated.
Re: ecm schematic (biggin)
1. Welcome to genvibe 2. What do you have planned that you need the ECU schematic?3. http://forums.genvibe.com/zero...m.jpg is a ECU pin numbering diagram from the GM supercharger instructions, but doesn't list which signals are on which pins4. DISCLAIMER - The attached pdf is for a 2003 Matrix, and it may be the same for a 2005 Vibe, or it may not, I have no idea, USE AT YOUR OWN RISK on a 2005 Vibe, It is a pinout/wiring diagram, not a schematic of the internals, but it is all I have.
Attached files 016ecs.pdf (157.4 KB)
