2003 vibe radio lights not showing
2003vibeowner
Post by 2003vibeowner »
I have a 2003 Vibe GT. The radio works fine but the display where the time and station show up is not lit. Does anyone know if this could be just a fuse that needs replacing? Any input would be appreciated. Thank you in advance.
ramenboy...
Re: 2003 vibe radio lights not showing
Post by ramenboy... »
Hey welcome. Post pics of the gt
As far as the radio goes, I believe the display is backlit, so the bulbs are out.
de-badged o4 vibe
o2 triumph speed four
Mariachi
Post by Mariachi »
ramenboy... wrote:Hey welcome. Post pics of the gt
this happened to mine. the lights did go out. that's why i just replaced the factory stereo with a double din.
Doug14
Post by Doug14 »
Have had this issue twice, it began to dim on one side then blacked out completely. I tapped it with my finger the first time and it came back on. and the second time it came back on its own after being off for a couple hours. Not sure what happened but give I'd give it a while before you replace it. Mine still works fine
leemur
Post by leemur »
my 04 was going dim on the right side. then the sound went out on the left and I figured I needed a new radio. Then 2 weeks later i noticed the display was fine, turned it on and the sound was fine also. This was the second stock radio. The fist one was replaced under warrentee for a ground fault. Never really believed that they swapped it.
2004 Fusion Orange, bought new R.I.P. 2009 Carbon Grey 2.4, bought new. 2004 Neptune bought used-2013
Depending on skill level, you can replace the LCD backlight bulbs in the OEM radio
viewtopic.php?t=26889" onclick="window.open(this.href);return false;
