Yeah, the Beetle had a steel band that held the shift boot and knob on the shifter. The only way to get it off was to cut the steel band with a Dremel and cutting wheel, and pull straight up, then you had to use a wire tie to reinstall, PITA. Typical German engineering, over complicated.
Old slot racer. 2009 Vibe GT owner
