clutch safety switch
cool vibes
Post by cool vibes »
I don"t know if this was brought up before? in order to get the car started you had to push the clutch all the way to the floor" so just a i went out to Can Tire and bought these sticky rubber stoppers i belive that you can use them on shelving . put them on the upper clutch bracket where it contacts the safety switch and it works no more pushing to the ground""""
Sub-Vibe-R
Re: clutch safety switch (cool vibes)
Post by Sub-Vibe-R »
I did the same with mine.I added a 1/4" plastic piece with 3M 2 sides tape.No more "jump-on-the-clutch-to-start"
Vibe Rater
Post by Vibe Rater »
Cool. What size was the rubber stopper you bought?
cool vibes
Re: clutch safety switch (Vibe Rater)
They look about the size of your finger nail"
cool vibes
You can buy a package of them cheap >clear color
russ257
Post by russ257 »
i am not a big manual driver but isnt it a good thing that you have to push the clutch in to start the car i mean it is a safety feature. please explain
Re: clutch safety switch (russ257)
It's definitely a good idea to have to push the clutch in to start the car. However, on these cars, the position of this safety interlock switch is not adjustable. On my car, I had to really mash the clutch into the floor. Other people have used thicker floor mats and have not been able to start their car. By putting a small spacer on the back of the clutch pedal arm, you can make it so that you don't have to push the pedal through the floor to start it. Also, on mine, it would take a 2x4 or so behind the pedal to hit the switch and have the clutch still engaged. We're only talking about a small adjustment, not enough to defeat the interlock. That would be easier done by jumpering around the switch, which would be a bad idea.
russ257
Re: clutch safety switch (joatmon)
Post by russ257 »
ahh now i understand i thought you were entierly defeating the switch an adjusment in spacing makes more sense
