Discoloration of console?
Has anyone else noticed that parts of their console appear to be discoloring? I thought at first it might be coffee stains, so I got some hot water and whatnot, but quickly realized it was not a stain at all, but an actual change in the color of the console plastic...I thought maybe it was a place where my plastic protectant (AKA armour all) wore off, but when i reapply, those areas still remain discolored.Is this a defect in my plastic?Is this a problem for anyone else?Is this something that would be covered under warranty?Here is just a small sample of what I'm referring to. You can see the areas circled are where i draw concerns, as they won't even absorb the armor all...
msmyer
Re: Discoloration of console? (ragingfish)
Post by msmyer »
Huh...that’s different! Can you take a picture a little further back....it's burry!
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
Re: Discoloration of console? (msmyer)
Yeah, unfortunately, it's dark out, so I did the best I could.I'll try to get a better one in broad daylight tomorrow.
huy397
Post by huy397 »
What's the depicted part?It doesn't look any differnt to me , maybe just plastic been worn off a little ?
Car: 2003 Two tone Base Frosty Vibe, Automatic, Safety & Security Package, Power Package and 16" alloys with 16" Blizzaks for winterNavigation: HP iPAQ 2210 + LeadTek 9537 BT GPS + iGuidance V2.1.1 + German-D mount.http://www.howardforums.comYour Mobile Phone Community & Resource
Re: Discoloration of console? (huy397)
Nah, definitely discolored.I'll get a better picture tomorrow.
msmyer
Post by msmyer »
I can kinda tell, it's hard though! I'll take your word for it, till i see another pic! LoL
satur9
Post by satur9 »
yeah mines like that . i thought it was because of the stuff i used to clean it even though the stuff says its safe for all plastic. but no matter what i put on it, plain water or even dry rags, it gets worse . i just dont touch it anymore. i hate cheap plastic interiors!!!!!!!!!!!
Re: Discoloration of console? (satur9)
Anyone know if Mother's B2B might work? I tried to get a better pic, but the sun just hasn't hit it right yet to be able to see the discolorations...
Re: Discoloration of console? (silverawd26)
quote:Try it on a part of it and see what happens. I was hoping someone else might've already tried so I don't become the guinea pig...because if it doesn't work, and makes it worse, I'll flip!
quote:Use the back portion area toward the rear seats? Or the side near the seat, the size of an quarter. To act like a 3rd grader for a minute, "you go first!"
fire_502
Post by fire_502 »
Have you tried your dealer yet? I bet they'll replace it. I just had the silver dash part around my radio replaced because the silver was peeling off around the volume knob. That's more wear and tear than plastic discoloration. Maybe you should call and see what they say first, then try it. If they flat out tell you to screw off, would you replace it out-of-pocket anyway? If so, try the B2B. But if they tell you they'll replace it under warranty, then try it anyway and see what happens so you can tell the rest of us . The question is, will it happen on the next one? Maybe yours came out of a bad batch of plastic or something. Good luck though!
Re: Discoloration of console? (fire_502)
The console lists at $235.93 US. I don't think I'll be buying a new one thank you very much.
Bring it down to $10, $20 tops, we can talk about it...anything more, SEE YA!
Re: Discoloration of console? (Salsa!)
I don't think so...more of it happens on the top surfaces, rather than inside the holders...where stuff never is...
If you didn't, maybe your dealer used some chemical on it if your radio and console are both affected. Some of this plastic is pretty sensitive. Any other interior plastic problems? Anybody else with a Vibe from the same dealer with the problem?
starman1980
Post by starman1980 »
I have never put anything on my dash or console excepet hot water because of the type of plastic, my buddys neon has the same plastic amor all relly looked bad if you miss spots or it wears off
dmitri
Re: Discoloration of console? (starman1980)
Post by dmitri »
my vibe from the dealer had a problem too. they used some chemicals to clean it and you can see drip marks and bad discoloration on the interior door panels. I was pissed but im not gonna spend my time going back i have no proof it was them theyll charge me for a new one.
Pump233ca
Post by Pump233ca »
Many of my interior parts are discoloured...the moulding process has to be the blame....I pointed them out shortly after I got the car...put them on record.....can`t blame me for wear and tear. Oh and by the way don`t stick one of hose deodorizer thingys in your vents, my wife did..and it leaked some juice...permanen t stain!!
Re: Discoloration of console? (Pump233ca)
quote:don`t stick one of hose deodorizer thingys in your vents, my wife did..and it leaked some juice...permanen t stain!!Haven't a clue what you're referring to!
fire_502
Post by fire_502 »
they look kind of like little Glade Plug-ins. A little scented cartridge slides into a plastic cartridge and the cartridge cllips into the vent face. At least that is what I think he is talking about.
May have found a solution --whatever is staining my console seems to come off with GooGone. I was scratching at it with my nail, and something was coming off, which proved it wasn't a plastic discolouration, but in fact, some sorta junk just stuck to it...it was dark so I just wiped off some areas...will check tomorrow to see if it really cleaned it, or the cleaner juts temporarily "hid" it.Will follow up with details tomorrow...
