Ya, that's the new model of the Kenwood I bought years ago. Looks like the changed the look a little, but the remote is the exact same. It looks like the specs are the same except for the speaker dimensions. My old one is two 6 1/2" speakers and the new model is two 5" x 7" speakers. I bet they did that to utilize the most space. Here's my old one.
http://www.crutchfield.com/S-m....html Andy, I would totally recommend it if you're looking for something to fill out your sound system. I use the frequency controls to have it handle most of the lows and leave my Infinity speakers upfront to handle the mids and highs. Here's the Infinity speakers I put in when I bought the sub and also put in some cheaper Pioneer speakers in the rear doors. They have some tweeters built in that you can aim.
http://www.crutchfield.com/S-Z....html I drilled some holes in the plastic on the back of the seat and put in those plastic inserts that expand and lock when you put in the screw. Retainers? Can't remember the term. I put a neoprene heat resistent foam pad behind the sub and screwed in the brackets and sub. Ran the power, cables, and remote down behind the seat, along the door jam, and under the carpet to the stereo. As you can see, it doesn't take up much space. It does exactly what I was looking for. Never had any problems with it either. It's been through many Oklahoma summers and winters, which go to the extremes at times. It's durable, sounds good, and just works. If you have any questions on that Kenwood sub, just ask. As far as I can tell, it's the same one I have, other than the speaker shape.
