04 Vibe ignition wire help
jasle
Post by jasle »
well, bought a vibe as a project with the head removed and in a million pieces. cannot figure out where to plug this wire in. car will start and run but is hard to start and runs rough. any help appreciate.
djkeev
Re: 04 Vibe ignition wire help (jasle)
Post by djkeev »
What year Vibe? (OK '04) What engine is in your Vibe? 2WD or 4WD?Dave
(o ! /o) (o)=I=(o)
jasle
Re: 04 Vibe ignition wire help (djkeev)
Post by jasle »
its a 2004GT , 2WD 1.8This wire is coming off of the #1 coil. Coming from the driver side the harness goes to 4,3,2,1 this is the last single wire sticking off the end. blue/red. has a holder on it to clip somewhere. about 6 inches in total length.thanks
welcome to genvibecould it be the power steering pressure switch? On mine (which is a base, not a GT) it goes down to the power steering pump, which is low on the rear passenger side of the engine.
jasle
Re: 04 Vibe ignition wire help (joatmon)
Post by jasle »
hmm, that could be it. too dark to see where it might plug in but it does reach and there is nothing currently plugged in the pump...but I found another problem. timing chain tensioner is not installed...and not in the spare parts I got...bummer.
