Lug nut size
KennedSR
Lug nut size
Post by KennedSR »
I got myself a set of MB Five X 16x7 with the 5-100/114.3 bolt pattern for the winter to go with my snow tires. I am stepping down from 18 inches to 16 inches. Stupid me did not buy the lug nuts that went with the wheels when I originally bought them. I looked around but could not find the size for certain. I just wanted to see if you guys agreed that the 16 inch base model tire lug nuts would be 12 x 1.50. From NAPA auto parts it looks like the Conical Acorn type would work for my wheels but again I wanted to see what you guys thought. Thanks in advance for assisting a first time DIYer
Re: Lug nut size (KennedSR)
12x1.5 as I recall, is the correct thread.
Re: Lug nut size (star_deceiver)
Yep, 12x1.5 .
KennedSR
Post by KennedSR »
Thanks for the quick response both of you. I was pretty much freaking out as to how I was going to get these wheels and tires on and I did not want the wheels falling off half way through my drive to work.
cchean
Re: Lug nut size
Post by cchean »
I know this is an old thread, but maybe someone can chime in and help. My '06 Vibe has alloy wheels and I know the lug nuts should be 12x1.5, but what about the length and seat? Acorn style seat or flat with washer???
Re: Lug nut size
the alloy wheels take the flat with washer, the steelies get the acorns.
an example of flat with washer nuts for Vibe alloys is
https://www.dormanproducts.com/p-10227-611-211.aspx
although I'm not sure if these have a separate floating washer, or if one is needed. maybe flat flanged is a better descriptor
cchean
Re: Lug nut size
Post by cchean »
Thanks for replying. I wanted to try aftermarket ones and this is the one that was interested in:
https://www.amazon.com/gp/product/B07R7 ... 174K&psc=1
