Well the rear diff oil seals are leaking again on the vibe. Had them replaced around 30k at a dealer and when the car came back the new seals were leaking worse, so they were replaced again. Now at about 70k one seal is leaking badly. I would rather not take it to the dealer a half hour away and fix it myself, i have the mechanical ability to do so. Anyone know where i can get the seals and what the part number is? i have had no luck finding them online.
2006 Vibe AWD, Platinum/Graphite, Sun and Sound Package - Sisters
2007 Vibe FWD, Neptune/Graphite, Base
PAST - 04 Shadow Base, Moons and Tunes, Monotone, Traded at 23K for the 06 AWD.
well looks like i will hit the toyota dealer, want to have the new parts before i disassemble the car. im positive its not over filled, it was not leaking for about 30k then started a slow leak that has only got worse. It leaked enough to completely drain the rear diff a few times now and i have been refilling it monthly now.
well looking deeper on genvibe i was able to find the toyota and gm part numbers and online sites to order them.GM **969361(old) SEAL DIFF CARR OIL,(PART OF 9,36),(42MM ID, 65MM OD),(15.5MM THICK)Replaced by: **2053502needed - 03-06 -$19.35eaToyota 90311-42033 (old) SEAL, OIL (FOR REAR DIFFERENTIAL SIDE GEAR SHAFT)Replaced by: 90311-42046 2needed $7.36ea I think i will be ordering the toyota ones.http://www.toyotapartszone.com...=true
