06 AWD rear diff seal leak again, part #s needed
04shadowvibe
Post by 04shadowvibe »
Well the rear diff oil seals are leaking again on the vibe. Had them replaced around 30k at a dealer and when the car came back the new seals were leaking worse, so they were replaced again. Now at about 70k one seal is leaking badly. I would rather not take it to the dealer a half hour away and fix it myself, i have the mechanical ability to do so. Anyone know where i can get the seals and what the part number is? i have had no luck finding them online.
2006 Vibe AWD, Platinum/Graphite, Sun and Sound Package - Sisters
2007 Vibe FWD, Neptune/Graphite, Base
PAST - 04 Shadow Base, Moons and Tunes, Monotone, Traded at 23K for the 06 AWD.
cq358
Re: 06 AWD rear diff seal leak again, part #s needed (04shadowvibe)
Post by cq358 »
is it likey they over filled the diff.?
If you have the old seals take one to an industrial supply store that specializes in bearings. The Toyota dealer can order them for you.
04shadowvibe
well looks like i will hit the toyota dealer, want to have the new parts before i disassemble the car. im positive its not over filled, it was not leaking for about 30k then started a slow leak that has only got worse. It leaked enough to completely drain the rear diff a few times now and i have been refilling it monthly now.
04shadowvibe
well looking deeper on genvibe i was able to find the toyota and gm part numbers and online sites to order them.GM **969361(old) SEAL DIFF CARR OIL,(PART OF 9,36),(42MM ID, 65MM OD),(15.5MM THICK)Replaced by: **2053502needed - 03-06 -$19.35eaToyota 90311-42033 (old) SEAL, OIL (FOR REAR DIFFERENTIAL SIDE GEAR SHAFT)Replaced by: 90311-42046 2needed $7.36ea I think i will be ordering the toyota ones.http://www.toyotapartszone.com...=true
cq358
Post by cq358 »
opps
