Reading/Map Light
Gorjes
Reading/Map Light
Post by Gorjes »
I have a 2003 GT. The Reading light up by the moonroof controls burnt out? I cant find anything in the manual about it, except how to turn it on/off. Any idea how to get to it or what bulb it takes? Thanks in advance
Never frown, it could be the moment someone falls in love with your smile.
Re: Reading/Map Light (Gorjes)
it's a #1895 bulbTo get to it, you have to remove the one screw you can see on the cover, then pry/pull the whole cover off. Don't try to take off just the clear plasticon mine, I rarely use it and sometimes it won't come on, but if I hit the switch on and off enough times, it starts to work. Might worth trying a hundred cycles on the switch to see if that cleans it up before buying a replacement bulb
cptnsolo77
Post by cptnsolo77 »
I have searched high & low for this particular bulb. Local auto parts stores dont carry it. I have tried ebay but cannot find a correct match. The wattage always seems to be off. Any suggestions?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Re: (cptnsolo77)
Go for an LED one. I went full-LED on my interior lights and it lights up the night. Just plug and play. Although the dummy plug I had to go into the spot where the bulb went did have the polarity wrong, so I had to switch the wires, but that might be seller-specific. They're all over ebay. I didn't get bulb-specific ones, they just sent me the LEDs and dummy bulbs.
cptnsolo77
Re: (KITT222)
Thanks for the advice. How much did you pay for the map light?
Gorjes
Re: (cptnsolo77)
Post by Gorjes »
Thank you so much for the bulb # and the pic and play by play! (Much needed . It was burnt out. For anyone else, they have the bulbs at Advance Auto Parts. Thanks again
