Slow leak
jake75
Slow leak
Post by jake75 »
I must have a very slow leak in one of my tires. The tire pressure warning came on today. The left rear tire was down to about 23 psi. It has been awhile but I think that tire lost air when it was on the left front and I got the same warning. After adding air that time I kept checking it for a couple of months and it didn't seem to be losing air. Last rotation was 6 months ago and it was ok at that time. After bringing up the pressure today the warning light went off - didn't have to do any reset or drive it. I carry a portable inflator with me at all times. At home I have a Black & Decker prortable battery (Versapak) operated inflator which is easier to use.
Re: Slow leak (jake75)
sounds like the pressure warning system was useful. give the tire a good visual next time you rotate them, maybe you picked up a nail
Re: Slow leak (joatmon)
My Vibe GT has been very "tight" and thus never needed any air to this day (2.5 years old & counting) ..... BUT our son's 2009 Vibe GT has TWO tires, both in front & worn pretty bad (37000+ miles on them) that lose air very slowly. One requires air about every 6-7 weeks and the other about every 4-5 months. YES ... I'm glad we have the TPS system to alert this of the low tire condition
2014 Silverado, 2004 Vibe GT
cq358
Re: Slow leak (tpollauf)
Post by cq358 »
you might need to soap the whole tire and find the leak
jake75
Post by jake75 »
Quote, originally posted by joatmon »sounds like the pressure warning system was useful. give the tire a good visual next time you rotate them, maybe you picked up a nailI put those tire pressure monitor value stem caps on my 2007 T&C that does not have the warnign system so you can visually check to see if there is underinflation. Go them on eBay.
