I hear the engine whinning through rear speakers
jjhendri
Post by jjhendri »
Hello GenVibers, hope you can help me with this. A couple of days ago, I started hearing the engine whine through the rear speakers. What could this be and how to fix. '03 Vibe GT, I had the front door speakers replaced about a year ago. ANy help would be appreciated.
Re: I hear the engine whinning through rear speakers (jjhendri)
Used to be that meant time to change the points and condenser but probably a bad ground somewhere, I have no idea where to suggest you look. Hopefully someone will post up something useful.
lovemyraffe
Post by lovemyraffe »
I notice a whine from my speakers when I am on the AUX input and don't have my iPhone plugged in.
MotoAce51
Post by MotoAce51 »
I heard old pioneer head units could ground through the antenna some how, and it caused more of a BUZZ sound.... Not sure if it helps. But its an idea.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
jjhendri
Post by jjhendri »
Thanks for the responses joatmon, laovemyraffle and MotoAce51. I have installed a Pioneer DEH-3200UB (got from Crutchfield in April 2011). No problems when it was installed. So may lead me to believe as all of you have indicated a bad ground or maybe blown speaker. I was going to change the speakers anyway so I'll hoping this will solve the issue unless some other GenViber weigh in.
MotoAce51
Post by MotoAce51 »
Pioneer's always have ground issues from what I hear. Still, its all I ever run in my cars....
bigdaddyjosh
Re: (MotoAce51)
Post by bigdaddyjosh »
It could be some kind of interference. Is the whine high pitched and do you notice the pitch going up as you accelerate?
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
jjhendri
Re: (bigdaddyjosh)
Post by jjhendri »
Hi bigdaddyjosh, it's high pitch and does do up as I accelerate.
bigdaddyjosh
Re: (jjhendri)
I believe that means you are experieincing EMI (Electro-Magnetic Interference.) Do you have any kind of amp on your speakers? I have had this happen to me many times and it was because the installers ran unshielded or bad RCA cable alongside my power wire. I believe the way it works is that as current is going through a wire it produces magnetic waves that radiate out and then travel into whatever wires are around.
jjhendri
Re: (bigdaddyjosh)
Post by jjhendri »
Hi bigdaddyjosh, the only amp is the M&T amp (stock).
bigdaddyjosh
Re: (jjhendri)
I don't have a M&T system so I can't help as far as that goes. But it could still be an issue with that amp or wires.
