hey guys i have a 2003 pontiac vibe automatic transmission i pretty much got it in there except for the ignition wires im not sure how they are supposed to be ive been reading alot and still cant figure it out an anyone give me a detailed description of where i hook up the starter wires,ignition wires, how do i hook up the wires to the ignition harness???????? do i needa bypass somehow??? anything im missing.....??
idk man maybe thi will help u guys help me i have an 03 vibe auto transheres the 10 wires i need to connect PINK(+) IGNITION 1 INPUT/OUTPUTH3/2RED/WHITE(+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87H3/3ORANGE(+) ACCESSORY OUTPUTH3/4VIOLET(+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)H3/5GREEN(+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)H3/6RED(+) FUSED (30A) IGNITION 1 INPUTH3/7PINK/WHITE(+) IGNITION 2 / FLEX RELAY OUTPUTH3/8PINK/BLACK(+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAYH3/9RED/BLACK(+) FUSED (30A) ACCESSORY/STARTER INPUTH3/10NC (no connec- tion)NCwhere exatly would i conne t each one of them if i connect them at all..
These are for the alarmPINK------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESS ORANGE-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS VIOLET-----Starter 1 RED (+) IGNITION SWITCH HARNESS(CAR SIDE OF THE STARTER KILL)GREEN-----Starter 1 RED (+) IGNITION SWITCH HARNESS(KEY SIDE OF THE STARTER KILL WIRE)These are for the Remote startRED------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESSPINK/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESSPINK/BLACK-----Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/BLACK-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS The starter wire will need to be cut in half. the side going to the ignition switch will be the key side, the wire that will be going to the car will be the starter side. Please test all wires with a test light or a multi-meter prior to hook up. it has been a while since I've done a remote start or alarm.
Quote, originally posted by Krystian »H1/2 Red (+) 12VDC Constant InputH2/17 Brown (+) Brake Shutdown Input--------------- This wire needs to go to the battery as it needs to be hot at all times.The brake input also has to be wired.
