viper 5901 alarm/remote start install help plss!!!
Krystian
Post by Krystian »
hey guys i have a 2003 pontiac vibe automatic transmission i pretty much got it in there except for the ignition wires im not sure how they are supposed to be ive been reading alot and still cant figure it out an anyone give me a detailed description of where i hook up the starter wires,ignition wires, how do i hook up the wires to the ignition harness???????? do i needa bypass somehow??? anything im missing.....??
MotoAce51
Re: viper 5901 alarm/remote start install help plss!!! (Krystian)
Post by MotoAce51 »
If I remember correctly my grand am was just spliced into the wires. I think it was yellow. But again, thats the grand am not the vibe.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
jayman2009
Post by jayman2009 »
ill try to take a look at mine tommrow as i have almost the same alarm in mine
Krystian
Re: (jayman2009)
Post by Krystian »
yes pls pls do my cars sitting till i get it hooked up take some pics if you may
keithvibe
Post by keithvibe »
you can download the service manual for the matrix and use that to find the right wire you need to connect to.http://pdftown.com/PDF-Toyota-....html
Krystian
Re: viper 5901 alarm/remote start install help plss!!! (keithvibe)
Post by Krystian »
idk man maybe thi will help u guys help me i have an 03 vibe auto transheres the 10 wires i need to connect PINK(+) IGNITION 1 INPUT/OUTPUTH3/2RED/WHITE(+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87H3/3ORANGE(+) ACCESSORY OUTPUTH3/4VIOLET(+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)H3/5GREEN(+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)H3/6RED(+) FUSED (30A) IGNITION 1 INPUTH3/7PINK/WHITE(+) IGNITION 2 / FLEX RELAY OUTPUTH3/8PINK/BLACK(+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAYH3/9RED/BLACK(+) FUSED (30A) ACCESSORY/STARTER INPUTH3/10NC (no connec- tion)NCwhere exatly would i conne t each one of them if i connect them at all..
Sublimewind
Post by Sublimewind »
THis is why in my 15 or so years of car audio, I've never done an alarm... Pure headache..
Krystian
Re: (Sublimewind)
Post by Krystian »
tell me about it... 3 days and still cannot come up with the solution
audiovibe
Post by audiovibe »
These are for the alarmPINK------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESS ORANGE-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS VIOLET-----Starter 1 RED (+) IGNITION SWITCH HARNESS(CAR SIDE OF THE STARTER KILL)GREEN-----Starter 1 RED (+) IGNITION SWITCH HARNESS(KEY SIDE OF THE STARTER KILL WIRE)These are for the Remote startRED------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESSPINK/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESSPINK/BLACK-----Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/BLACK-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS The starter wire will need to be cut in half. the side going to the ignition switch will be the key side, the wire that will be going to the car will be the starter side. Please test all wires with a test light or a multi-meter prior to hook up. it has been a while since I've done a remote start or alarm.
Vibe is gone and will be missed as I've gone country style
Krystian
Re: viper 5901 alarm/remote start install help plss!!! (audiovibe)
Post by Krystian »
man this **** is getting to me here are all the wires and where i hooked them up please tell me where i went wrong.... ty Just copy and paste what you think should work. thx lol i bet im missing alot lol or just a little dumb mistake lol.Main Harness (H1) 12 pin connectorH1/1 Red/White (-)200mA Aux/Trunk ---------- Not connectedH1/2 Red (+) 12VDC Constant Input ----------- 12 V White & black (IGN Harn)H1/3 Brown (+) Siren Output ------------------- Siren (+)H1/4 White/Brown -Parking light isolation ----- Not ConnectedH1/5 Black (-) Ground -------------------------- Ground at driver kick panel boltH1/6 Violet (+) Door Trigger Input ------------- Not connectedH1/7 Blue (-) Trunk Pin -------------------------- Not ConnectedH1/8 Green (-) Door Trigger Input ------------ Red/White(-)Interior light SwitchH1/9 Blck/White(-)200mA Dome light output-- Not ConnectedH1/10 White/Blue(-) Remote start/turbotimer input-------Not connectedH1/11 White ----Parking light output--------------Not ConnectedH1/12 Orange (-) 500ma Ground when armed----Not Connected H2 Harness 18-Pin ConnectorH2/1 Light Green/Black (-) 200mA OEM Alarm disarm Output -- Not ConnectedH2/2 Orange/Black (-) 200mA Aux 4 output ---------------------Not ConnectedH2/3 Green/White (-) 200 mA OEM Alarm Arm Output---------- Not NonnctedH2/4 Violet/Black (-) 200mA Aux 2 output ------------------------Not ConnectedH2/5 White/Black (-) 200mA Aux 3 output ------------------------Not ConnectedH2/6 White/Violet (-) 200mA Aux 1 output ------------------------Not ConnectedH2/7 Grey/Black (-) Diesel wait to start----------------------------Not ConnectedH2/8 Brown/Black (-) 200mA Horn Honk Output ------GreenYellow(-)@Steering H2/9 Violet/White--- Tachometer Input ------------------------white @ ignition coilH2/10 Dark Blue (-) 200mA Status Output----------------------Not ConnectedH2/11 Pink/White (-) 200mA Flex Relay Control Output--------Not ConnectedH2/12 Orange (-) 200mA Accessory Output----------------------Not ConnectedH2/13 Purple (-) 200mA Stater Output----------------------Not ConnectedH2/14 Pink (-) 200mA Ignition 1 Output----------------------Not ConnectedH2/15 Grey (-) Hood Pin Input (NC or NO) ---------------------- Hood PinH2/16 Blue/White (-) 200mA 2nd Status Output/rear Defogg----Not ConnectedH2/17 Brown (+) Brake Shutdown Input---------------H2/18 Black/White (-) Neutral Safety Input----------------------Not ConnectedDoor Lock 3-pin Connector 1-Blue (-) 500mA Unlock OutPut----------------- Blue/Yellow (Driver Kick Panel)2-Empty----------------------------------------------------------------------------------3-Green (-) 500mA Lock OutPut ------------------Green (Driver Kick Panel)Remote Start (H3) 10-Pin ConnectorH3/1 Pink (+)Ignition 1 Input/Output-- Ignition 1 Black/White(+)Ignition HarnessH3/2 Red/White (+) (87) Flex Relay Input (30A Fused)--- Ign 2 (Black/yellow)H3/3 Orange (+) Accessory Output ------------------------ Blue/Red (Ign Harness)H3/4 Violet (+) Starter OutPut -----------Red starter wire car side (Ign Harness)H3/5 Green (+) Starter Input ------------Red starter Wire Key side (Ign Harness)H3/6 Red (+) Ignition 1 Input (30A Fused) ------------ Ign 1 Black/WhiteH3/7 Pink/white (+) Flex Relay Output -------------------ign 2. Black/yellowH3/8 Pink/Black (+) Flex relay input ----------------------ign 1. black/whiteH3/9 Red/Black (+) Acc/Starter Relay input (30A Fused) -accessory red/ blue
audiovibe
Post by audiovibe »
Quote, originally posted by Krystian »H1/2 Red (+) 12VDC Constant InputH2/17 Brown (+) Brake Shutdown Input--------------- This wire needs to go to the battery as it needs to be hot at all times.The brake input also has to be wired.
Krystian
Post by Krystian »
the brake is wired but ill try hooking it to the battery
Krystian
Post by Krystian »
still dosent work man idk (removed)... (removed)
audiovibe
Post by audiovibe »
Could be any number of things, my advise would be to take it to a pro. to hard to trouble shoot through the net.Sorry
