I am new to the genvibe board and just purchased a 2004 Vibe 1.8 liter with automatic. It is neptune blue ( solid exterior) , tunes and moon package, abs, power package and 17 inch aluminum wheels. The vehicle has 95,000 miles so I am starting to sort it out over the next month or so with trying to get the front and rear alignment squared away next week. I had the local tire dealer check the alignment after installing 4 new tires and the alignment figures were way off and they said the alignment wasn't adjustable. From reading the forum and talking with another alignment shop in the area, it sounds like I need to get front camber bolts in the front and rear alignment shims to get the alignment in check.The other item is gas mileage. The first tank so far was 25 MPG which was a bit less than I was expecting after moving from a 1997 Camry that got 26 - 29 MPG very consistently. I probably need to install new plugs, a new air filter and clean the MAF and see if that improves things. Any other suggestions would be greatly appreciated.Looking forward to using this forum and driving the Vibe.
