Any body have any luck with this
supervibe
Post by supervibe »
I installed it but dont see now difference? there are times when the GT will run like a bat of of Hades. so dont know if this works part time or was it a scam.......................... http://slrmotorsports.com/shop...p=690
RIT
Re: Any body have any luck with this (supervibe)
Post by RIT »
When something sounds too good to be true, it usually is not true. If it were that easy, GM would have offered it as a $1K option !
Serj22
Re: Any body have any luck with this (RIT)
Post by Serj22 »
you might have had better luck installing headlight fluid and elbow grease. Also tighten your muffler bearings because you've been had. Crack that box open and you'll find a resistor. Yes, a 12cent resistor from radio shack and a sticker. It causes a CEL because there wasn't a resistor in that spot on the circuit before, after a while it goes away and the ECU learns there is nothing wrong and ignores it. The CEL makes it seem like something has happened and the computer is like "Oh my gosh, (removed)! All this power! What do I do?!" but nothing happened except an error. When I did mobile audio for a shop, I used to pop these open for customers and show them an empty box with a weight and a resistor. It was a usually speechless reaction, or anger. Some of them have knobs on them to "adjust" the airflow or some junk, it's not attached to anything, it just spins and stops.Good luck on getting your $80 back. BTW, it drives like a bat out of hell sometimes because you mashed your foot on the gas pedal thinking there was something to be felt, you felt WOT on a stock car and $69 of thought-provoking speed, that's all.
Pioneer HU2 x D3tAK tweeters in stock location (M&T)4 x Diamond Audio D162.5i1 x Pioneer TS-W309S4 SubPolk Audio Pa330 (To drive Sub)
supervibe
Re: Any body have any luck with this (Serj22)
Post by supervibe »
Should I remove it? is a hinderance?
BlueCrush
Post by BlueCrush »
Sounds like the stock ECU might be fighting it which is why the Vibe might run great one time and not the next.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
A Psycho Martyr
Post by A Psycho Martyr »
Quote, originally posted by RIT »When something sounds too good to be true, it usually is not trueI've always been skeptical about these for that exact reason Sounded too good to be true
Salsa Guy
Post by Salsa Guy »
If you think it's causing problems (power changing) then remove it. Anytime you are changing signals without a proper fuel managment it can cause problems.
Serj22
Re: Any body have any luck with this (rmckinjr)
Post by Serj22 »
I'm telling you guys, it's a loving resistor in a box. Same people that buy them buy the electric supercharger, vortex intake tube, and magnetic fuel rail...
Salsa Guy
Post by Salsa Guy »
Here's a link where this guy tore one down. Interesting reading. http://www.hondamarketplace.co...99407
supervibe
Re: Any body have any luck with this (A Psycho Martyr)
Post by supervibe »
Ok I was suckered I'm pulling the POS off and maybe with some new plugs, clean maf, *throttle body , pvc valve, VVT valve it will once again run & get the mileage.
epcIII
Post by epcIII »
Oh well, everything is a learning experience...
SlammedNiss
Post by SlammedNiss »
(removed). Did you really pay $70 for that?And do I dare say it? This item falls into the same category as those $100 grounding wire kits.
2011 Rav4 Sport
Salsa Guy
Re: (SlammedNiss)
Post by Salsa Guy »
I was planning on doing a ground upgrade with out the Kit. And maybe adding one of those voltage stablizers. I've had problems with coil packs and wondering if the ground to the engine is iffy.
