terrible idle, car dieing
BLACKEDOUTVIB
Post by BLACKEDOUTVIB »
i am idleing at like 400-500 and whhen i start it up in the morning after like 30 seconds of sitting at idle it dies. even after i have been driving for 20 minutes i pull up to a light, and it just idles at 500-600, and sounds terrible like a knocking noisei have the Cosmo Cold Air Intake and no other modsany ideas?PLEASE HELP i wanna keep it ion but tempting to put stock air box on
BLACKEDOUTVIB04 Abyss Vibe 5 spdCosmo Racing Cold Air Intake Custom Cat-back Exhaust20% Tint All AroundAlpine Head Unit, Eclipse 800w Amp, 2 12" subs ported/neon. Carbon Fiber Shift Knob
BlueCrush
Re: terrible idle, car dieing (BLACKEDOUTVIB)
Post by BlueCrush »
This might sound weird, but how old is your battery?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
B14CK_H4WK
Post by B14CK_H4WK »
clean idle control valve. maybe new sparks
keithvibe
Post by keithvibe »
Did this start when you put the cosmo on?If so, maybe the MAF sensor isn't seated properly and is leaking air.also, there are issues with the intake manifold gasket could be failing and causing a leak... it's an easy fix.
BLACKEDOUTVIB
i found the problem,my grandpa got me spark plugs couple weeks and said he gapped em already, well he didnt, so im pretty sure thats the problem
dgekiere
Re: (BLACKEDOUTVIB)
Post by dgekiere »
hopefully they were the right iridium plugs, isaw apost awhileago where soeone got the wrong plugs and it ran bad and was dieing. you said your grandpa bought them maybe he got the wrong ones.good luckhttp://forums.genvibe.com/zerothread?id=40274this was the one i was thinking about
2003 VIBE GT, CONVERTING TO RALLY CAR. http://forums.genvibe.com/zerothread?id=463112004 vibe gt magnaflow catback exhaust (bought totaled 9/06 with 1600 miles, fixed it and in love ever since2004 HONDA CBR1000RRASE Master certified mechanic
If it's the iridiums like what were in there OEM, you're actually not supposed to gap them.I had mine idle like dump once (never died, just idled really low and rough,) the dealer ended up cleaning the throttle body.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
BLACKEDOUTVIB
so can someone give me a little checklist on what to check?i have autos next hour and am going to check out the plugs...anything else??i am lowering it, getting rims, tinting it, and custom exhuast but i need this fixed before i do any of thesee so please help me outtt
A Psycho Martyr
Re: (ndrewoods)
Post by A Psycho Martyr »
my car did the EXACT same thing RIGHT after I installed my SRI....Maybe it has something to do with the intake?I too have been thinkin bout going back to stock inake.About a week later tho, it cleared up. It's done it once or twice randomly, but runs great otherwiseDoes anyone know wht the hose going to the intake is? it's function?Not thread-jacking, just wondering if it's related
Could it be a vacuum line disconnected/uplugged/hooked up to the wrong thing?
A Psycho Martyr
Re: (joatmon)
well i tried finding out what the vaccuum line was and I'm convinced it's the crankcase ventilation tube....any confirmation?
BLACKEDOUTVIB
mine went away idk what happened maybe it just needed to adjust.physcho could you make me a sick signature?
Serj22
Re: (BLACKEDOUTVIB)
Post by Serj22 »
Having installed a lot of CAI's, and usually doing I/h/e on every car I've owned, I will atest to the fact that when the instructions say "disconnect the battery and remove" they are covering two steps. Most installs, you can leave the battery in, install the intake, and start the car and it will run like normal but with a low idle. The computer is still trying to operate the statistics of the normal intake, but that's not going to work, since the old intake isn't there anymore. Thus you get a crappy run. If you disconnect the battery for 15 minutes, however, the ECm will reset and when you reattach the battery, the car will "learn" the new intake and treat it as normal and adjust to that. So when you remove it in the beginning (it's going to take more than 15 minutes to get the new intake in) you are killing two birds with one stone, so to speak.If disconnecting the battery didn't work, try cleaning the IAC, or adjust the idle screw. I too just got a cosmo CAI, since price doesn't mater on these things, it was $40 2nd party on E-bay, and a tube is a tube, so it's going in tomorrow. The filter it came with isn't worth junk, but that's not an issue to replace.
Pioneer HU2 x D3tAK tweeters in stock location (M&T)4 x Diamond Audio D162.5i1 x Pioneer TS-W309S4 SubPolk Audio Pa330 (To drive Sub)
A Psycho Martyr
Re: (BLACKEDOUTVIB)
Quote, originally posted by BLACKEDOUTVIB » pyscho could you make me a sick signature?I'd love to. Lemme know what you want and send me some decent pictures
