Remote start pricing
09vGT
Post by 09vGT »
I stopped by a local reputable stereo shop that also sells and installs remote starters. The price for the remote starter and install is $200.00. Then the guy tells me that I'll have to have something that will bypass it, but I don't think that my has to have one; it does NOT have the security system and there are not any type of security lights that light up when starting the car. I told the dude this but he insisted it has to have it. I'm not 100% sure, but want to find out before I dish out $70.00 for the bypass. Does the pricing sound okay, or is it overcharged? I have no idea when it comes to these types of things. The remote start brand is an AutoPage RS-60 http://www.autopageusa.com/t_i...c27ec Its strictly just a one button remote start, no alarm or any other keyfob functions. Thanks!
keithvibe
Re: Remote start pricing (09vGT)
Post by keithvibe »
local shop to me charges 250 installed, just for the car starter.So the shop your dealing with is right on track, IMO
audiovibe
Post by audiovibe »
The 09s do have an immobilizer that is bypassed with an RF signal from the key. Side bar Autopage does make nice R/S units.
beemerphile1
Post by beemerphile1 »
I just got a remote start installed last week in my 2009. Even though almost all manuals say a bypass is needed, I can tell you without a doubt that NO BYPASS IS NEEDED!I previously had a key cut at the hardware store to prove that the key had no transponder or resistor. I then found a shop that would do the install without a bypass initially and only add it if needed. IT WASN"T NEEDED!I intend to do a full write up soon when I get time.Total cost $150, have been using it for a week now and everything works great.Disclaimer; This is for a US model with NO factory security system.
audiovibe
Post by audiovibe »
Good to know, Thanks for the corrections!
09vGT
Re: (beemerphile1)
Post by 09vGT »
Okay, so the real test will be if I get a key cut at like WalMart and the car starts.. I DO NOT need the bypass then? Like I said.. I have no security lights at all, unlike my old mustang that would say THEFT when I started it.. But I know it was chipped..
SlammedNiss
Post by SlammedNiss »
Only the Canadian models require a bypass module. If you want, just take off your steering shroud and see if it has a black plastic ring with wire attached to it around the key cylinder. If so, you have an immobilizer and will need a bypass. BTW, if you're looking to install one yourself, I can get you the RS with keyless for $120. Can get you the bypass for another $35 if your car needs it. It's an AutoStart US1475 made by DEI, the same makers of Viper and Python. http://www.autostart.ca/prodIn...US%29
2011 Rav4 Sport
