Remote for door locks stopped working
bertherr
Post by bertherr »
One of my two remotes for the door locks stopped working for my 2005 AWD Vibe. The battery is good in this remote. None of the buttons will do anything to the car.Do I have to replace it? Can I test it somehow?Thanks, Bert
audiovibe
Post by audiovibe »
How did you test the battery? Did you drop the remote in a puddle by any chance? Have you tried to reprogram the fob?
djkeev
Re: Remote for door locks stopped working (bertherr)
Post by djkeev »
Sorry to insult, but is the battery in correctly? They do have a + and a -The two sides are awfully similar and the battery CAN be inserted upside down.If it isn't this, I'll go with the post above, what unusual things happened to the FOB?Dave
(o ! /o) (o)=I=(o)
bertherr
Re: Remote for door locks stopped working (djkeev)
Post by bertherr »
This remote was not dropped into water or anything like that. It just stopped working.I tested the battery with a voltmeter. I also tested my other remote's battery with a volt meter. They both showed a little over 3 volts which are marked on the battery. I even tried switching the batteries between the remotes. No changes.I did not try reprogramming the remote because I do not know how. I was hoping that someone would post this procedure for me so I could try that.Thanks, Bert
Quote, originally posted by bertherr »I did not try reprogramming the remote because I do not know how. I was hoping that someone would post this procedure for me so I could try that.They did (seven years ago ) http://forums.genvibe.com/zerothread?id=1437Quote, originally posted by NovaResource »Don't be afraid to add the new remote. Here's how to do it without deleting the old codes:http://forums.genvibe.com/zero...e.jpg
bertherr
Re: Remote for door locks stopped working (joatmon)
Post by bertherr »
I'll give the method for adding a remote, in the last link, a try tonight.If I were to use the method where you can program up to 4 remotes, would it matter which remote I started with? Also, is this doing anything to the key itself? Does the key have a chip in it?Thanks for the links, Bert
bertherr
Post by bertherr »
I went through the process for adding a remote. The car did respond to all of the key and door cycles by flashing the lights and lock/unlock the doors. But, it did not respond to the required button pushing on the remote. I guess something has fried in the remote. BTW, the other remote still works. Bert
SlammedNiss
Post by SlammedNiss »
Mine recently quit working as well. Thought it was the battery (it's the original battery from 8 years ago) but didn't work even with a new battery.. Haven't tried reprogramming yet.
2011 Rav4 Sport
Blueridge9
Re: (SlammedNiss)
Post by Blueridge9 »
Sorry to read about your remote not working. When I bought my Vibe used it did not have a remote. I bought one for a Toyota Matrix and programmed it myself for the Vibe and it works great. I even left it in my clothes and put it thru the washing machine once (duh) and it STILL worked. Here's where I got it: http://www.carandtruckremotes.com.
Blueridge9 2004 Base, 1.8L "The Vibe is a melding of muscular looks, ..utility & economy, sportiness & road-hugging tractability." -Road & Track Magazine Sept. 2008 Pictures: http://s278.photobucket.com/user/blueridge9/library/" onclick="window.open(this.href);return false;
bertherr
Re: (Blueridge9)
Post by bertherr »
I just ordered one myself earlier today off of eBay. Thanks, Bert
bertherr
Re: (bertherr)
Post by bertherr »
FYI, the remote I purchased from ebay programmed perfectly. Bert
