Air conditioning trouble, please help!
idmaestro
Post by idmaestro »
ok here's the low-down on the trouble I'm having:'04 vibe, 80k milesair blows hard, but is warm, about the same as the outside tempplenty of refrigerant (40 psi,) no leakscompressor cycles on and off properlythis problem began suddenly, not graduallyruled out relay switch and fusesanyone have any ideas, tips, or suggestions? I don't want to spend a fortune on parts that I don't need...
Bikerscum
Re: Air conditioning trouble, please help! (idmaestro)
Post by Bikerscum »
Well, if everything is as you say.... AC system seems to be ok, I would suspect the ductwork.... a door/bypass/cutoff/whatever is not letting the cold air into the ducts. Broken cable, that kinda thing. Good luck.
djkeev
Post by djkeev »
If you put it on defrost and set the temp low, do you get cool air blown onto the windshield??
(o ! /o) (o)=I=(o)
first thing I'd do would be to rule out the problem discussed in http://forums.genvibe.com/zerothread?id=1315
fss106
Post by fss106 »
I'd bet money its your a/c compressor clutch-- seems to be a reoccurring problem around here. http://forums.genvibe.com/zerothread?id=41023
'03 Vibe GT (manual/6 speed)
