Courtesy Light
schmooobie
Courtesy Light
Post by schmooobie »
My son was changing out the bulb on the roof when he shorted it out. The light itself works if you turn it on manually but it doesn`t work when you open the door, neither the front or rear. The switches are in the correct position. Does anyone know what circuit or module it goes to.
Re: Courtesy Light (schmooobie)
check the dome fuse in the underhood fuse block
Water boy
Post by Water boy »
Hummm...I'd first guess operator error.The fuse must be good since the light actually lights.I don't see how the "short" could cause the door circuit to go bad.I'd pull the dome light assy out and give it a look-see with a DVM.
2008
47,891 Added new horns
69,036 Added sound deadening
70,395 Battery
schmooobie
Re: (Water boy)
turns out that it is connected to the Multifunction Alarm Module and it might have fried when it got shorted.
Re: (Water boy)
Quote, originally posted by Water boy »The fuse must be good since the light actually lights.I've got an old fashioned Vibe, none of this door or fancy switch on the light stuff. If it was an 03, I'd say maybe the dimmer switch is set to off, but I don't know if that's even an option on this dark Vibe.
