How to install Energy Suspension Bushing - front control arm done.
yyamad1
Post by yyamad1 »
I did the passenger side this time to complete this job. Still took 1.5 hrs from start to finish. The difference is incredible. Biggest difference I noticed is the handling improvement during cornering. Much less body roll during lane change. Still using 16inch snow tires so I suspect it will ride better come spring! I took more pictures to show more detailed steps of this mod. hope it helps someone out. Yohei
yyamad1
Re: How to install Energy Suspension Bushing - front control arm done. (yyamad1)
Post by yyamad1 »
HEY i made a word doc file less than 2mb and posted. it does not show it... what should i do? can a moderator post it?
I sometimes have trouble attaching large files. Try putting the pics in photobucket and copy/paste the written stuff here.
vibedrivermatt
Post by vibedrivermatt »
very interesting. Looking forward to seeing those pictures.yup star deceiver has the right idea. I also use photobucket to post all my pictures on this site.you gotta upload the pictures there.. then copy and paste the IMG code into your post.the code will be between two IMG's.
yyamad1
Re: How to install Energy Suspension Bushing - front control arm done. (vibedrivermatt)
Post by yyamad1 »
http://s917.photobucket.com/al...stall/i did as u instructed, all pics are there. too bad they have no caption but if u read the how to.. just seeing the pics will probably clarify everything. y
Sublimewind
Post by Sublimewind »
Bushings are usually one of the last things people do... which is backwards thinking really... I mean if you put a quality suspension under the car, and have all of the attachment points of the suspension bushed with bubble gum, that great suspension you just spent good money on, can't properly do it's work... Good show mate..
