I did the passenger side this time to complete this job. Still took 1.5 hrs from start to finish. The difference is incredible. Biggest difference I noticed is the handling improvement during cornering. Much less body roll during lane change. Still using 16inch snow tires so I suspect it will ride better come spring! I took more pictures to show more detailed steps of this mod. hope it helps someone out. Yohei
very interesting. Looking forward to seeing those pictures.yup star deceiver has the right idea. I also use photobucket to post all my pictures on this site.you gotta upload the pictures there.. then copy and paste the IMG code into your post.the code will be between two IMG's.
http://s917.photobucket.com/al...stall/i did as u instructed, all pics are there. too bad they have no caption but if u read the how to.. just seeing the pics will probably clarify everything. y
Bushings are usually one of the last things people do... which is backwards thinking really... I mean if you put a quality suspension under the car, and have all of the attachment points of the suspension bushed with bubble gum, that great suspension you just spent good money on, can't properly do it's work... Good show mate..
