09 Vibe AWD Hatch wont lock
Airmack
Post by Airmack »
If I lock the doors from inside the car or using the remote lock on the key, the hatch does not lock. I can open it from the outside every time. Is it a switch or some thing I am missing or do I need to take it in?
Re: 09 Vibe AWD Hatch wont lock (Airmack)
Can you lock it physically with the key?If it's only using the power locks function (switch or remote) then it could be the actuator inside the hatch, or perhaps a bad connection. Since it's an 09, I'd say take it back to a dealer and get it fixed under warranty, except its always such a hassle to lose the time to have to go back to the dealer, so hopefully someone else will post up a quick and easy fix.
Airmack
Re: 09 Vibe AWD Hatch wont lock (joatmon)
Post by Airmack »
Quote, originally posted by joatmon »Can you lock it physically with the key?If it's only using the power locks function (switch or remote) then it could be the actuator inside the hatch, or perhaps a bad connection. Since it's an 09, I'd say take it back to a dealer and get it fixed under warranty, except its always such a hassle to lose the time to have to go back to the dealer, so hopefully someone else will post up a quick and easy fix.good thinking, I missed the key lock on it & that does work. But I pulled out the PDF from the GM website & it says (Lock): Press to lock all of thedoors and liftgate.
at least you knkow that part of the mechanism isn't siezed up, and you have a way to lock it until the electric method is restored.Does the switch or remote unlock the door? If so, the wires to it are probably ok. If you press the lock button, can you hear (or feel) anything happening in the hatch?
Airmack
Re: (joatmon)
Post by Airmack »
Quote, originally posted by joatmon »at least you knkow that part of the mechanism isn't siezed up, and you have a way to lock it until the electric method is restored.Does the switch or remote unlock the door? If so, the wires to it are probably ok. If you press the lock button, can you hear (or feel) anything happening in the hatch? i have not put my ear to it to check but i dont hear any thing like i do when the side doors lock. got a apt for this coming monday
beemerphile1
Re: (Airmack)
Post by beemerphile1 »
Maybe you got a Monday built Vibe that has power door locks but a hatch door with only a manual lock. Could happen, I've seen bigger goofs than that.
Airmack
Post by Airmack »
it was the actuator
