Can anyone tell me if when closing the moon roof, it stops halfway closed, and you have to release the close button and resume pressing to get it completely closed? I took mine in to be looked at and was told "this is normal operation". I would like some feedback from other owners to ensure what they say is correct! Thanks!
TraceyShadow, Two Tone, Auto, Moons and Tunes, Cargo Mat & nets, first aid pouch, storage pouch, Power Pkg, Theft system, Auto Pkg
My sunfire was opposite. You pressed the open button once, it opened to vent position. Push it again, it opened full on it's own. Closed without stopping.There is no reason we can't have express open on this moonroof, and certainly, the whole "stop halfway" thing is absurd. Can't be a safety issue. Only if the moonroof closed on it's own would that be for safety. Because you have to hold the button down, IMHO, it's just stoopid.
There are 2 separate buttons-one for tilt, one for slide. They work independantly (and there is a sliding cover inside in case it is too sunny I guess)
quote:The Vibe moonroof is different (2 button system) since it slides into the roof not over the roof like the Sunfire's moonroofRight. But I still think it should function the same way...
It's probably because 2 different motors are being worked, thus 2 switches. One motor to put the back end up/down for the tilt function, and another to slide it into the roof or back out and up. I really don't mind the 2 presses to close it....it's my first moonroof though...so it could just be me.
has anyone thought about lighting up the switches for the moon roof . meaning on the switch you only see the slide and the tilt like on durangos that say unlock on the doors. or like the GTP steering wheel.. . . .
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
Quote, originally posted by ragingfish » the whole "stop halfway" thing is absurd. Can't be a safety issue. .But it is. big brother ( the government) is watching and he doesn't want anyone to get a pinched or missing limb so they can sue little sister's (GM) (removed) . kinda like the Mcdonalds coffee issue.stupid? yes. but sueing a manufacturer because they didn't use common sense is getting to be pretty popular with the american public. so GM (and other companys) have to cover their butts
like Salsa said, the difference is that in a sunfire (like my wife's Grand Am) the opening is a sunroof....where the glass slides over the roof. There you can get away with one switch (first position is tilt open, second is open all the way). In the Vibe, it is a moonroof....the glass goes into the roof. So now you need 2 motors....one to tilt up, and one to slide the glass back into the roof.That's a lot of roofs.......
I had an aftermarket moonroof on my Ford Probe. It would either vent, or open. To vent, you held the switch to the close position until it vented. Hold it to open and it would close, hold open again and it would fully open the roof. No automatic movement, you'd have to hold the switch the whole time, but it was only one switch...
Quote, originally posted by futseal04 » In the Vibe, it is a moonroof....the glass goes into the roof. So now you need 2 motors....one to tilt up, and one to slide the glass back into the roof.My 1984 Volkswagon Quantum GL5 had a Metal moonroof that only had one switch. You pushed it one way for the back to pop up. You pushed it the other way and it closed, if you then released the button and pushed it again it would sink down into the roof and slide all the way back (didn't stick out of the roof like the Vibe's does a little bit). It only had one motor and one switch. It also had an emergency function. If the roof wouldn't close you could pull down on the light/switch assymbly and you would see a allen wrench hole. The allen wrench crank was attached to the back of the light/switch assymbly. Then you could just crank it closed (or open).
I had a sunroof on my 99 Chrysler Sebring LXI and it had one switch that you would use to open and close but it would go up over the roof not inside like the Vibe and it had the same feature as the Vibe that closed half way stop then push again to close complete.
