17" Tire Fitment
brbo
17" Tire Fitment
Post by brbo »
Morning folks,I've gone through all teh archives and tire threads but can not confirm one person that has run a 225/55R17 on their pre '09 Vibe.. I have a screaming deal on tires in that size but want to know if anyone has had this size and what they thought about them,,Thanks for the help, Cheers
ClunkClunk
Post by ClunkClunk »
Sorry I'm no help - 215/50R17 on mine.
2008 Frosty two tone (and 3 other Vibes)
dragon64
Re: 17" Tire Fitment (brbo)
Post by dragon64 »
225/ 45-17 would be the correct equavelent size to the stock size. A 55 series tire would be over diameter
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
brbo
Post by brbo »
I've used the calculator I know the variations that I can use - I'm wondering if the 225/55 fits ??
Sublimewind
Post by Sublimewind »
It'll fit fine.. It'll be tall though...
brbo
Post by brbo »
Really with no rubbing inside the wheel well ?? Have you tried these tires ??
HighMileVibe
Re: (brbo)
Post by HighMileVibe »
It has just as much to do with the wheel offset in regard to rubbing as to the tire size. Best bet is to use the tire size calculator spreadsheet I made below and measure your current tire tightest fit point. You can then figure out if the larger tire still has room to fit.The 225/55 17 IS 7.0% larger than the stock size. Which will result in a 7% LOWER speed indication and mileage accumulation. You mpg relative to your trip odo will appear to have dropped by this same 7% though you gain a little back with the effectively 7% taller gear ratio.
Attached files wheel_tirecalculator.xls (26.5 KB)
2006 Platinum base, Auto, 145k miles+, now a 2004 Matrix 190k+ mods: Leather wheel, Homelink dimming mirror, ribbed cargo mat, blackberry mount, Jensen VM8023HD HU, mudflaps, bumper guard, double armrest Other cars: 97 Accord Coupe, 2000 GMC Savana conversion, 97 Miata M-edition. http://forums.genvibe.com/zerothread?id=37345 http://www.gotlife.org
brbo
17" Tire Fitment
Post by brbo »
~MRVIBE2006~
Post by ~MRVIBE2006~ »
It seems that the tire size that you have a great deal on is possibly too big for your application. Look and use the tire size calculator sticky at the beginning of this forum and calculate the size and you'll see that its 7% too big. You can also have the tire installer test fit the tires for you and if they fit with no clearance issues, then go for it. But I would shy away for a tire that too big regardless if your getting a good deal on them or not. Plus bigger tire equal lower MPG also.
2006 ABYSS VIBE: 20% TINT ALL AROUND FRONT & REAR SPLASH GUARDS MAGNAFLOW CAT-BACK EXHAUST GOODYEAR EAGLE GT (235/45/17) WITH TC WHEELS (SUMMER) DUNLOP WINTER SPORT M3 (215/55/16) ON STOCK ALLOYS (WINTER) AUTO VENTSHADE WINDOW VENTS PLUS SUNROOF VENT K/N AIR FILTER,OTHER DRESS-UP GOODIES...
