2003 vibe blower fan doesnt work at all
hazard37
Post by hazard37 »
the fan quit blowing and the ac light wont light up i replaced the resistor and the motor will work if u hook 12v to it also the switch and relay are good also the fuses any help would be appreciated
Old Tele man
Post by Old Tele man »
...I believe there's an "electronic module" between the switch and the fan...one of it's functions is to 'remember' the last setting that you pressed...so, maybe the module electronics has lost its memory and died?
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
hazard37
Post by hazard37 »
thanks i finally got it fixed.
Sublimewind
Re: (hazard37)
Post by Sublimewind »
What was the fix???? not very constructive of we don't know how you did it..
