the fan quit blowing and the ac light wont light up i replaced the resistor and the motor will work if u hook 12v to it also the switch and relay are good also the fuses any help would be appreciated
...I believe there's an "electronic module" between the switch and the fan...one of it's functions is to 'remember' the last setting that you pressed...so, maybe the module electronics has lost its memory and died?
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
