transmission whine
jak219
transmission whine
Post by jak219 »
Anyone have a whiny transmission? Mine (2008) makes a high pitched whine that follows the engine speed. It is starting to bug me.
yippeekyaa
Re: transmission whine (jak219)
Post by yippeekyaa »
Auto or manual?
Re: transmission whine (yippeekyaa)
from the pic jak posted in http://forums.genvibe.com/zerothread?id=34097 I see he has an auto tranny ( http://forums.genvibe.com/zero...n.JPG )jak, you say it's a tranny whine, but follows the engine speed. What makes you think it's the transmission?
jak219
Re: transmission whine (joatmon)
Post by jak219 »
Yeah, it's an automatic. If I put it in neutral, and increase RPMs, the sound is not there. That's why I think it's the transmission. It sounds kind of like when you rub something against the outside of a sleeping bag or backpack or ski jacket. But it is continuous. Like one of those old wind sound effect machines where there's a rotating drum rubbing against a piece of material (http://www.ruyasonic.com/sfx_make.htm). It's not loud, but it's noticeable.
THE VIBERATOR
Post by THE VIBERATOR »
I know what you mean. It's the computer. Not the transmission. It's a very high pitched whine right? It's the computer making the noise. For some strange reason.
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
jak219
Re: transmission whine (THE VIBERATOR)
Post by jak219 »
nah... the computer? Any idea how/why the computer would make noise like that?
impalamike3800
Post by impalamike3800 »
just out of curiosity what tires are on there? ill check on alldata at school tomorrow I dont see how it could be the ECU being how they do not have fans in them. its just a circuit board in there. sounds like you have single chain gears which i applaud (the double chain final drive gears on automatic transmissions are much quiter than single chains due to the chains 180* off set allowing noise cancelation, single chains are 10 times stronger). id like some video of this condition to make a more educated deduction.
THE VIBERATOR
Re: (impalamike3800)
It's like a whirring, whining sound if i'm not mistaken. I know exactly what you mean, but it sounds like it's coming directly from the ECU. I'm probably wrong, but that's the general area from where the noise is originating.
impalamike3800
does the car have a fenderwell intake? they tend to make alot of noise when driving. the sucking sound in the fenderwell gets magnified alot in any car/application.
