all the pros out there.....question for ya!!!!
dillpickle
Post by dillpickle »
would a kicker resolution r6c 61/2 fit in the rear door....?????
KSNeptune
Re: all the pros out there.....question for ya!!!! (dillpickle)
Post by KSNeptune »
Measure one (diameter and depth). Then measure the opening (diameter and depth).Then you can answer your own question.My best guess would be "sure". Just save your receipt so you can take them back if they don't fit.KSNeptune
Idsane
Re: all the pros out there.....question for ya!!!! (KSNeptune)
Post by Idsane »
yes it does, I have them. I had to make custom brackets for them however, the speaker will not screw into the panels without them.
dillpickle
Re: all the pros out there.....question for ya!!!! (Idsane)
but what are u asking for them brackets or are they easy to make????and how do they sound. I have 6 1/2 polk conponent speakers up front and I'm looking for something that'll give me more bass (because the tweeters are very high) would that do the job or should i go tro something like a 2 way.....thanks
NY Pete
Post by NY Pete »
Your Polk's fit up front without much trouble? I have a st of JL XR650.CSi's waiting to go in after I get my car tinted...Pete
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
cohocarl
Post by cohocarl »
quote:I had to make custom brackets for them however, the speaker will not screw into the panels without them. They will not fit in the rear door? Can you explain the problem you had which required brackets please. Thanks,Carl
dillpickle
Re: all the pros out there.....question for ya!!!! (NY Pete)
I'm just getting them in as we speak....got a set of off a friend of mine and he had it on his vibe.. but he said if you go to crutchfield for all the thing you need, it will be no trouble what so ever
