Measure one (diameter and depth). Then measure the opening (diameter and depth).Then you can answer your own question.My best guess would be "sure". Just save your receipt so you can take them back if they don't fit.KSNeptune
but what are u asking for them brackets or are they easy to make????and how do they sound. I have 6 1/2 polk conponent speakers up front and I'm looking for something that'll give me more bass (because the tweeters are very high) would that do the job or should i go tro something like a 2 way.....thanks
quote:I had to make custom brackets for them however, the speaker will not screw into the panels without them. They will not fit in the rear door? Can you explain the problem you had which required brackets please. Thanks,Carl
I'm just getting them in as we speak....got a set of off a friend of mine and he had it on his vibe.. but he said if you go to crutchfield for all the thing you need, it will be no trouble what so ever
