I've noticed recently, when I turn the wheel at low speeds, the steering column creaks. Anyone know what's going on or how to fix it? Edit: and I didn't spell noise correctly.
“I live my life free of compromise, and step into the shadows without complaint or regret.â€
Quote, originally posted by northvibe »maybe it needs some lubrication at the joint part? do you know if its from the column or in the engine bay? It might be in the engine bay, it sounds kinda distant.
it should be in the engine bay on the drivers side, most likely need a flashlight to see it, it's farther down and probably underneath the airbox tube that runs from the box to the throttle body..you might even have to go underneath the car to get at it
Quote, originally posted by VforVIBE »Edit: and I didn't spell noise correctly. Fixed that for ya... oh and it would be "creak" as well, but who's counting?
Quote, originally posted by millster »Fixed that for ya... oh and it would be "creak" as well, but who's counting? At least Creek is a word... even if it is the wrong one.
Quote, originally posted by NibCrom »Did you check your power steering fluid?no, I'll have to do thatQuote, originally posted by NibCrom »Is it possible it's something entirely different, like the brakes?Nah, it's definitely has to do with turning the wheel.
hey v, can't help you, only to say that probably something needs lubrication. sorry,but, i also wanted to say that if you were on the south side of chicago, then there would be no problem with 'noice'as in 'ey. i got some noice over der by da steering wheel'good luck
de-badged o4 vibe
o2 triumph speed four
