Creak noice
VforVIBE
Creak noice
Post by VforVIBE »
I've noticed recently, when I turn the wheel at low speeds, the steering column creaks. Anyone know what's going on or how to fix it? Edit: and I didn't spell noise correctly.
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
northvibe
Post by northvibe »
maybe it needs some lubrication at the joint part? do you know if its from the column or in the engine bay?
VforVIBE
Re: (northvibe)
Post by VforVIBE »
Quote, originally posted by northvibe »maybe it needs some lubrication at the joint part? do you know if its from the column or in the engine bay? It might be in the engine bay, it sounds kinda distant.
WaveAction
Post by WaveAction »
it should be in the engine bay on the drivers side, most likely need a flashlight to see it, it's farther down and probably underneath the airbox tube that runs from the box to the throttle body..you might even have to go underneath the car to get at it
millster
Re: Creek noice (VforVIBE)
Post by millster »
Quote, originally posted by VforVIBE »Edit: and I didn't spell noise correctly. Fixed that for ya... oh and it would be "creak" as well, but who's counting?
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
VforVIBE
Re: Creak noice (millster)
Post by VforVIBE »
Quote, originally posted by millster »Fixed that for ya... oh and it would be "creak" as well, but who's counting? At least Creek is a word... even if it is the wrong one.
VforVIBE
Re: Creak noice (VforVIBE)
Post by VforVIBE »
Anything else?
NibCrom
Post by NibCrom »
Did you check your power steering fluid?Is it possible it's something entirely different, like the brakes?
VforVIBE
Re: Creak noice (NibCrom)
Post by VforVIBE »
Quote, originally posted by NibCrom »Did you check your power steering fluid?no, I'll have to do thatQuote, originally posted by NibCrom »Is it possible it's something entirely different, like the brakes?Nah, it's definitely has to do with turning the wheel.
ramenboy...
Post by ramenboy... »
hey v, can't help you, only to say that probably something needs lubrication. sorry,but, i also wanted to say that if you were on the south side of chicago, then there would be no problem with 'noice'as in 'ey. i got some noice over der by da steering wheel'good luck
de-badged o4 vibe
o2 triumph speed four
