Threaded Bolt Holes under right front of front seat
asburydan
Post by asburydan »
I found 2 threaded bolt holes into the pan of the car under the front area of the front seat (on the raised area the seat sits on. My Vibe is '05 Base. Can anyone tell me what those holes are or could be for. I am attaching photos from two angles. Thanks.
asburydan - moved from Vibe to 5th Mustang.
asburydan
Re: Threaded Bolt Holes under right front of front seat (asburydan)
Post by asburydan »
Sorry, the photos didn't attach. The two holes are about 2" apart.
asburydan
Post by asburydan »
Here is the other photo. It worked when I didn't think it was doing so. Learned something.
northvibe
Post by northvibe »
i wonder if those are for the amp on the moons and toons package.....
asburydan
Post by asburydan »
My car had the moons and toons package when I got it last month with 34,500K . Other ideas?
Driver side is power inverter, passenger is M&T amp. Those are the only two things you'd find under the front seats.
Kamikaze
Re: (ragingfish)
Post by Kamikaze »
Only thing I could think of is if those are pre drilled from the factory for the amp for the Voltz (right hand drive so the amp would be on the left side)Just a guess....
the thread title says the holes are under the right front of front seat. This pic of yours shows the holes and a floormat hook So, the holes are under the right front of the driver's side seat? If my '03 has those bolt holes, the carpet is not cut away like it is in yoursMaybe they are for the external CD changer that came with the factory navigation head unit. EDIT, no, the external CD changer with the NAV system goes under the passenger seat, replacing the M&T amp.
asburydan
Post by asburydan »
Yes, the photo is taken at an angle showing floor mat hooks and the bar to move seat is above holes.
scherry2
Re: Threaded Bolt Holes under right front of front seat (joatmon)
Post by scherry2 »
just a question?is the front section of the floorpan exclusively vibe? it could be the front floorpan section of the Corolla and Vibe are interchangeable.In our plant the Chevy floor pan and GMC floor pan are the same sheetmetal but different locations for various things to bolt down to. just a guess though.
asburydan
Post by asburydan »
Another good idea. Thanks for your help. It is a curiosity to me, and I happened to find the bolt holes when I was doing a good cleaning.
keithvibe
Post by keithvibe »
they are there for you to ask questions about them
Raven
Re: Threaded Bolt Holes under right front of front seat (keithvibe)
Post by Raven »
That's where the strap for the nitrous bottle attaches if you order the Drag Pack option.
MRCN RCE
Re: Threaded Bolt Holes under right front of front seat (Raven)
Post by MRCN RCE »
Quote, originally posted by Raven »That's where the strap for the nitrous bottle attaches if you order the Drag Pack option.yep. too bad that wasn't available for the california vibes honestly i have no clue what those could be for... hmm
