http://www.ground-control-stor...CA=89 what do you guys think of these?...is this a good price....im thinking of doing it maybe sometime...like the Vibe GTR, Vibe FXdoes anyone have the adjustable suspensions?...if not what springs do you use...lowered how much?...
personally, if you are looking for coilovers, then you should invest the money and just get them. the struts go with the spring set up and are designed specifically for them. just mho.
x2getting just the coil sleaves and slaming your vibe down on struts that aren't ment to perform like that will just ruin your struts in about 3-6month timeframe. talk to petertracks... http://www.neverenoughauto.com k-sports are the way to go.. 800bucks and you have lots of adjustments.... you will be adjusting them till your ready to sell the vibe.
x3,The only combo using those springs were on adjustable struts (read KYB AGX) and that was only because you could match the strut valving to the spring rate more readily... For the price, it would be nice for you to try, but you would be left wanting something else...
