coilover conversion kit...
waveresponder
Post by waveresponder »
http://www.ground-control-stor...CA=89 what do you guys think of these?...is this a good price....im thinking of doing it maybe sometime...like the Vibe GTR, Vibe FXdoes anyone have the adjustable suspensions?...if not what springs do you use...lowered how much?...
AKLGT
Post by AKLGT »
personally, if you are looking for coilovers, then you should invest the money and just get them. the struts go with the spring set up and are designed specifically for them. just mho.
AKLGT1998 Subaru 2.5RS
keithvibe
Re: (AKLGT)
Post by keithvibe »
x2getting just the coil sleaves and slaming your vibe down on struts that aren't ment to perform like that will just ruin your struts in about 3-6month timeframe. talk to petertracks... http://www.neverenoughauto.com k-sports are the way to go.. 800bucks and you have lots of adjustments.... you will be adjusting them till your ready to sell the vibe.
Sublimewind
Post by Sublimewind »
x3,The only combo using those springs were on adjustable struts (read KYB AGX) and that was only because you could match the strut valving to the spring rate more readily... For the price, it would be nice for you to try, but you would be left wanting something else...
northvibe
Post by northvibe »
id say get the trd coil overs or teins, if your going to spend a lot on suspension and want the best, go all out. worth it in the end.
