My thermostat has been sticking this week here in Michigan so I need to install new one and Coolant. Anyone experience issues or have preferences with a type of coolant. And is the stock Thermostat ok to use as the replacement. With all the different Coolants just wanted a recommendation. Thanks all
I put the Prestone stuff in, twice now and it works just fine.
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
there is a true life time coolant by Peak. They call it Global $13/gal. It is compatible with all. Plus they warranty your cooling system if you document ithat it was flushed before you changed it to theirs. It's YELLOW. So it takes on the color of anything other coolant in there. I don't recommend Dexcool. Unless you absolutely change it before their 5 year recommendation. The original stuff is PINK Toyata long life. Orange is Dexcool. Don't let anyone tell you different.
Quote, originally posted by robdog »I put the Prestone stuff in, twice now and it works just fine.+1. Virtually all coolants now state on the bottle, 'safe for all metals and compatible with all brands and colors of coolants.
Quote, originally posted by jasonvibe »there is a true life time coolant by Peak. They call it Global $13/gal. It is compatible with all. Plus they warranty your cooling system if you document ithat it was flushed before you changed it to theirs. It's YELLOW. So it takes on the color of anything other coolant in there. I don't recommend Dexcool. Unless you absolutely change it before their 5 year recommendation. The original stuff is PINK Toyata long life. Orange is Dexcool. Don't let anyone tell you different.I have a 2003 and was told it was Dexcool - but if that were true I sort of questioned why the owner's manual said to replace every 24 months/30,000 miles whichever comes first. It looked orange to me. Under "what to use" the manual said "1/2 clean drinkable water and 1/2 coolant that meets GM Specification 1825-M with a completet coolant flush and refill."
