Removing Door Panel with Manual Window
pelican-vibe
Post by pelican-vibe »
Hi!This is my first post. I want to thank everyone in advance, because I've already read a lot of good advice that I've applied on my 2007 Vibe. I just bought a Pioneer CD deck and speakers for my Vibe and found the instructions to take out the door panel in the Forum, but after doing a search couldn't find instructions on how to remove the window cranks on my manual windows. Any help will be appreciated.Thanks,Frank GMiami, FL
kevera
Re: Removing Door Panel with Manual Window (pelican-vibe)
Post by kevera »
You have to get the clip off on the crank itself.I have a tool to do this or you can use needle-nose pliers,or you can use 2 jewellers screwdrivers and push the clip out.
Sublimewind
Re: Removing Door Panel with Manual Window (kevera)
Post by Sublimewind »
Quote, originally posted by kevera »You have to get the clip off on the crank itself.I have a tool to do this or you can use needle-nose pliers,or you can use 2 jewellers screwdrivers and push the clip out.Exactly as kevera said EXCEPT, you MUST make sure you catch that clip otherwise it WILL fly into the next county TRUST ME(it will fly).... we used to stock them as the shop i used to work at... If you push the door panel away from the handle, toward the outside of the car it will expose the clip... once you have the handle off, snap the clip back onto it so you don't lose it to...
pelican-vibe
You guys are great! What quick service! I could get used to this!Thanks a bunch!Frank GMiami, FL
KNINE
Post by KNINE »
I once saw an old timer remove the clip by sliding a strip of t-shirt behind the crank. The clip got snagged in the cloth and popped right out without losing it.
Re: (K-NINE)
I guess I'm an old timer too
RIT
Post by RIT »
WHen you go to put it on, it is easiest to put the clip back on the handle, then push the handle over the post. Always put the clip on with the opening facing the handle, so you will know which way to pull it off the next time.
Sublimewind
Re: (K-NINE)
Quote, originally posted by K-NINE »I once saw an old timer remove the clip by sliding a strip of t-shirt behind the crank. The clip got snagged in the cloth and popped right out without losing it.Holy CARP man, i've never thought of that..!!!!!!!!!!!!!!!!!!!!!!!!!!!!!+100,000,000,000...!!!! I've nearly taken people eyes out with those dam clips....
VibeHigher
Re: (Sublimewind)
Post by VibeHigher »
Using a strip of cloth like that is actually the recommended procedure in AllDataDIY
2003 Lava Vibe :: Moon & TunesMods from Dynamat, Blaupunkt, K&N and Motegi
