I would like to change the DRL modual so that the turnsignals are on all the time in "bright mode" i found this..Universal DRL and i was wondering how you install these?
It would be interesting to see that. Post pics if you do get it.I personally like thishttp://www.webelectricproducts...s.htmI might have to get this when I upgrade to LED lighting.
I have one of those. It worked great until the driver side bulb blew. It bubbled the inner lens in the process. Dealer replaced lens and called it a bulb malfunction. The pass side bulb blew today. it also bubbled the inner lens. We will see if the dealer will replace that one?? Need I tell you I also removed the DRL unit from the car today. I have used the same unit on other cars with out issue. I think the small area in the blinker lens is the issue. All in all I would not recommend it for the vibe. the guy that runs that site is great and a great guy to deal with.
