Passenger side NO seatbelt un-realing
viper
Post by viper »
I can't pull the front pass. seat belt out, how does the pillar trim panel comes off?
viper
Post by viper »
I meant un-reeling
Re: Passenger side NO seatbelt un-realing (viper)
I haven't done it, but found this in a headliner removal thread:Quote, originally posted by VibeForWinter »The Upper center pillar trim must come off. Remove the front and rear door sills, and then the lower trim (these pieces all just pull off). Pop the cover off the upper seat belt anchor, and remove the bolt holding the seat belt on, then you can pull the upper center trim panel.good to see you finally posting, sorry it's for a problem. hope it's an easy fix, let us know what you find in there
Whelan
Re: Passenger side NO seatbelt un-realing (joatmon)
Post by Whelan »
Don't pull fast
2012 GLI Autobahn 6MT
viper
Re: Passenger side NO seatbelt un-realing (Whelan)
Post by viper »
Yep, my first post and sorry to say for assistance. I hardly use the car but someone brough the belt to my attention. Thanks 4 the advice.
scherry2
Post by scherry2 »
something like that should be covered under the warranty.
viper
Re: Passenger side NO seatbelt un-realing (scherry2)
Post by viper »
The FIX/B] is, I found a piece 2x2" of mastic covered plastic wound/stuck to the belt w/in the reel. That removed the belt would reel freely. To re-attach the mouldings I found you need to pull the rubber gasket away first and press in last.I think the plastic covered a hole somewhere to keep out moisture.
