Reset Error Codes
Creslyn
Reset Error Codes
Post by Creslyn »
Can anyone tell me how to reset the error codes on a 2003 Vibe? I tried unhooking battery after 10 min or so it still had not reset.
02csnow
Re: Reset Error Codes (Creslyn)
Post by 02csnow »
Usually unhooking the battery to reset the computer normally works. You may want to go to a local auto store like Autozone or Advanced Auto Parts and have them reset it for you.
Bye Bye Vibe.............
kevera
Post by kevera »
It might mean you have a problem,get the code read.
satur9
Re: Reset Error Codes (kevera)
Post by satur9 »
you unhooked the negative terminal right? shouldve worked. your code is still pending if it didnt. get it checked soon.
Sublimewind
Post by Sublimewind »
If you care not to have the code read, disconnect the negative terminal on the batt and press the break pedal for a little while, or leave one of the doors open for a little bit... The bulbs will drain the system down...
zionzr2
Post by zionzr2 »
you can also reset it with a ScanGaugeII
