Usually unhooking the battery to reset the computer normally works. You may want to go to a local auto store like Autozone or Advanced Auto Parts and have them reset it for you.
you unhooked the negative terminal right? shouldve worked. your code is still pending if it didnt. get it checked soon.
If you care not to have the code read, disconnect the negative terminal on the batt and press the break pedal for a little while, or leave one of the doors open for a little bit... The bulbs will drain the system down...
