I say go with a full air ride managment kit. They are fully adjustable and allow you to lay out your vibe all the way without having to make tedious adjustments to each coil over. Plus riding on air is sweet anyway.Suicidedoors sells a kit for the vibe.
http://www.suicidedoors.com/03...t.phpThe kit includes:Lower your ride, improve your handling, and get control over your suspension. The most versatile choice for suspension on today's market. Go from the strip to the street to the show floor with the push of a button. Our air struts are designed to give you maximum performance with our 9-way dampening system previously only found on high end coilovers. Want to adjust your spring rate as well? No coilover will ever offer this option! Adjust your spring rate with the flip of a switch or use our optional "Auto Pilot" digital controller to set it and forget it. When style matters just as much as performance, our air struts will let you down... as low as you want to go. Wheel gap never helped anyone win a car show! Tuck those rims up where they're supposed to be. Combined with our F.B.S.S. air management system (included) this kit will set you on the ground, let you clear speed bumps, and get in and out of driveways without scraping your ride. Not to mention the remarkably smooth ride that air provides. So just to go over it one more time you get: (2) Front 9-way dampening Air Struts, (2) Rear 9-way dampening Air Struts, our fast F.B.S.S. air management system comprised of (8) Platinum Series 300psi chrome valves, (2) Dual Needle 200psi gauges, (4) switches for individual wheel control, chrome 200psi 100% duty cycle Viair compressor, 5 gallon (8) 1/2" ported air tank, all nickel plated push to connect fittings for leak free connections, emergency fill valve, drain (removed), 175psi pressure switch, 40 ft of 1/2" D.O.T. approved air line for fast air transfer, 50 ft of 16 gauge wire, and our air line cutter for added ease of installation. You won't find a more complete system for your ride!it uses air strutsThe kit comes with everything you would need to bag your vibe.Suicidedoors.com is the best company to deal with for airbag stuff. I use them all the time for my truck.
