Does the automatic trans Vibe have a transfer case and rear differential?
lexicon
Post by lexicon »
While looking at the owners manual,I found that theRear Diff takes 0.5 qts, doesnt say of whatTransfer case takes 0.8 qts doesnt say of what.Are these on the cars with Auto Tranny?Does anyone know what grade of fluid each of the above gets?
2005 VibeAutomaticStockNon AWD125 hp model
scherry2
Re: Does the automatic trans Vibe have a transfer case and rear differential? (lexicon)
Post by scherry2 »
that sounds like an AWD vibe. is that what you have?
lexicon
No, I have the 125hp automatic trans non AWD car
Post by lexicon »
Non AWDThanks
lexicon
Anyone know?
Post by lexicon »
I am trying to confirm if an automatic Vibe Non-AWD hasa Transfer case and rear shift diff?Just want to know if there is something other than the Transmission needs fluid changeThanks
BlueCrush
Re: Anyone know? (lexicon)
Post by BlueCrush »
Only the AWD has transfer case and a rear differential to drive the rear wheels. Transfer Case: http://en.wikipedia.org/wiki/Transfer_caseRear Differential: http://en.wikipedia.org/wiki/D...anics)
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Whelan
Re: Anyone know? (BlueCrush)
Post by Whelan »
Transfer case and FWD do not go in the same sentence. At least not when talking about one being in the rear.The AWD does only come with an auto tranny. If you look under your car and there is a pipe running down the middle to the back where you see a big silver box. You are AWD. If not, then those parts of the manual do not pertain to you.
2012 GLI Autobahn 6MT
