While looking at the owners manual,I found that theRear Diff takes 0.5 qts, doesnt say of whatTransfer case takes 0.8 qts doesnt say of what.Are these on the cars with Auto Tranny?Does anyone know what grade of fluid each of the above gets?
I am trying to confirm if an automatic Vibe Non-AWD hasa Transfer case and rear shift diff?Just want to know if there is something other than the Transmission needs fluid changeThanks
Transfer case and FWD do not go in the same sentence. At least not when talking about one being in the rear.The AWD does only come with an auto tranny. If you look under your car and there is a pipe running down the middle to the back where you see a big silver box. You are AWD. If not, then those parts of the manual do not pertain to you.
