Hi. I have a 2004 base Vibe and just purchased a set of drilled and slotted rotors with some EBC RedStuff pads. I was trying to remove the rotors and after banging on them repeatedly and taking the torch to them and banging some more I still couldn't remove them. It really does look like the hub and the rotor are one piece, I can't see a seam between the two and I was just wondering if anyone had seen an application where it was the same piece. I do have the repair manual and it shows it as two different pieces but maybe it is a pressed fit or something? Or if I have to take off the locking nut and remove the rotor/hub assembly how would I install the new ones? Is there some adapter plate you can buy?
Attached files 01900210.pdf (160.9 KB)
