Quote, originally posted by northvibe »I have a 2004 and the sun visors from my knowledge...dont extend..........but maybe i should double check...Same here. I have a2004, and NO side airbags, and NO extending Visors. Do you mean they just will slide over, or do you mena that they should have the little plastic peice that comes out and makes it longer?
I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
Quote, originally posted by VivaVibe »I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.I wonder if it's just the '05+ with the curtains that don't have the extensions? I can see where the curtain air bags would interfere with the extending visors, but maybe the ones from '04 that didn't have the curtains would be ok even if extended.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
I can verify at least the first part of your statement. My '05 with curtains and side airbags does not have them. With the information VivaVibe gave, what you said makes sense.
I'll be Hornswaggled! My 04 and 06 vibes both have them! I was flippin' through Genvibe for some good reading and found this subject. Had to run out and check! Thanks guys! Learn somethin' new everyday!
04 Salsa Monotone base, SUPERCHARGED! Auto trans , 6 disc 200w stereo, Alloys, K&N filter, Moons and Tunes, Silver Stars in both fog and head lights, And now Magnilow Cat back exhaust! 06 Lava Monotone Base Auto trans, 200w single disc XM, On-star Alloys, Moons and Tunes Loaded 96 Dodge Ram 2500 4x4 CTD Built trans #0 fuel plate and secret adjustments!
