What year Vibes have the sun visors that extend?
BlueCrush
Post by BlueCrush »
I need to find some and replace mine so I can get the sun out of my eyes while driving. Thanks!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ragingfish
Post by ragingfish »
i believe it was 2004+
2009 PONTIAC G8
BlueCrush
Re: (ragingfish)
Post by BlueCrush »
Thanks Ragin'. I also found this thread after searching a little more: http://forums.genvibe.com/zerothread?id=12946
My Fleet:
northvibe
Post by northvibe »
I have a 2004 and the sun visors from my knowledge...dont extend..........but maybe i should double check...
BlueCrush
Re: (northvibe)
Post by BlueCrush »
If you have side air bags you won't have them. If you don't have side airbag then you should have them
My Fleet:
kevera
Re: (BlueCrush)
Post by kevera »
I remember reading this a few years back.I forgot I even had these,thanks for reminding me.
Vibr8tr
Re: (kevera)
Post by Vibr8tr »
Quote, originally posted by northvibe »I have a 2004 and the sun visors from my knowledge...dont extend..........but maybe i should double check...Same here. I have a2004, and NO side airbags, and NO extending Visors. Do you mean they just will slide over, or do you mena that they should have the little plastic peice that comes out and makes it longer?
MSN: jjbova@hotmail.com - Yahoo: jjbova - Myspace: http://www.myspace.com/jjbovaSee My Vibe at Cardomain.com
BlueCrush
Re: (Vibr8tr)
Post by BlueCrush »
They are suppose to just slide out on the rail, the whole visor.
My Fleet:
Vibr8tr
Re: (BlueCrush)
Post by Vibr8tr »
ok, maybe mine do that. I know one does, but I can't remember if it's the Vibe or the Lancer. I will check afte work to verify
keithvibe
Re: (Vibr8tr)
Post by keithvibe »
06 with out side air bags..and I have them.
VivaVibe
Re: What year Vibes have the sun visors that extend? (BlueCrush)
Post by VivaVibe »
I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
kevera
Re: What year Vibes have the sun visors that extend? (VivaVibe)
Post by kevera »
I have an 04 and they don't extend.Are they suppose to pull down or are they able to slide to cover the side window?
Quote, originally posted by VivaVibe »I have an 04 base with side airbags and my visors DO extend, although they advise not to do it when forward, only while turned to the side window. There's really not much room to the rearview mirror while positioned in front.I wonder if it's just the '05+ with the curtains that don't have the extensions? I can see where the curtain air bags would interfere with the extending visors, but maybe the ones from '04 that didn't have the curtains would be ok even if extended.
Image Image
TRDman
Re: What year Vibes have the sun visors that extend? (ColonelPanic)
Post by TRDman »
I can verify at least the first part of your statement. My '05 with curtains and side airbags does not have them. With the information VivaVibe gave, what you said makes sense.
mcgusto82
Re: What year Vibes have the sun visors that extend? (TRDman)
Post by mcgusto82 »
my 04 with out side bags DID extend.
jsimon63
Post by jsimon63 »
I'll be Hornswaggled! My 04 and 06 vibes both have them! I was flippin' through Genvibe for some good reading and found this subject. Had to run out and check! Thanks guys! Learn somethin' new everyday!
04 Salsa Monotone base, SUPERCHARGED! Auto trans , 6 disc 200w stereo, Alloys, K&N filter, Moons and Tunes, Silver Stars in both fog and head lights, And now Magnilow Cat back exhaust! 06 Lava Monotone Base Auto trans, 200w single disc XM, On-star Alloys, Moons and Tunes Loaded 96 Dodge Ram 2500 4x4 CTD Built trans #0 fuel plate and secret adjustments!
Vibr8tr
Re: (jsimon63)
Post by Vibr8tr »
I too checked, and it has it, and I have an 04. So I am guessing they all had it. Good concept, but I have never used it
