empty spots in under dash fuse panel
satur9
Post by satur9 »
does anybody know if these can be used.are they always hot or ignition powered. i was thinking about adding fuse taps in them . it looks like it has terminals on boths sides of the empty fuse spot. so i dont know if the wire is dead ended somewhere .i could always use a blown fuse tap. so just the hot side where the aux tap is remains hot. but i just wanted to get other opinions see if anyone else has done this. before i screw my back up messing around down there. also does anybody know which wire ( hopefully near the shifter)( 5 speed btw) turns on the reverse lights.
Re: empty spots in under dash fuse panel (satur9)
the reverse light switch is on the tranny
satur9
Re: empty spots in under dash fuse panel (joatmon)
Post by satur9 »
do you have any idea where that wire or relay or whatever comes up into the car thats not all the way in the back by the lights
here's the diagram. Looks like no relay
Attached files 023bl.pdf (23 KB)
That diagram above says the wires come in via juntion "J3" which from page 6 of this PDF looks like it is behind the glove box somewhere
Attached files parts.pdf (289 KB)
satur9
Post by satur9 »
thanks
so what are you up to, needing all this odd information and stuff?
satur9
Post by satur9 »
i need power and a signal for revesrse. it should be obvious to someone like you.i asked about the fuses cause i already got a lot of stuff on my radio and lighters circuits.if you cant guess i'll have pics by tues.
I have a hunch, and it is not to hook up a reverse beeper so you can pretend to be a GT
zionzr2
Post by zionzr2 »
could it be a reverse seeing camera?
satur9
Re: (zionzr2)
Post by satur9 »
ding ding ding, we have a winner. theres a white harness with a black/red wire behind the glovebox. thats the reverse wire.(found in another post.) its all wired up but the cams not mounted so i'll get pictures in the daylight tommorow.
ChewieDaWookiee
Post by ChewieDaWookiee »
Have you ever found out what the empty spots in the under dash fuse panel were hot, engine running, or bogus?
satur9
Post by satur9 »
sorry never found out.i just tapped the radio and reverse wire and moved some other stuff.
ChewieDaWookiee
Re: (satur9)
Thanks. For getting back to me though.
keithvibe
Re: (ChewieDaWookiee)
Post by keithvibe »
some of the open spots are constant hot, some are igg. on.Use a tester light like I did to figure out which ones are which. All are usable though.
